View Full Version : HHR SS
Pages :
1]
11
12
13
14
- Performance seats
- FE5 struts
- Sudden onset of fuel delivery issues 08 HHR SS
- How many are orange??
- 15 years old & it still makes me giggle
- Blow Off plate Question
- Question about CTS-V brakes
- Possible to switch the ss to ls or lt knuckles?
- rear suspension noisy
- Engine Question
- Found a 09 half panel SS with 92k miles
- Odd LCA/ball joint combo
- Squeaky front end when turning left
- New 2010 HHR SS Owner
- New Problem- Smoke.
- Accent stripe
- Primary Chain Tensioner
- heater/A/C blower intermittency
- Looking at a 2008 SS - What should I watch out for?
- *NEEDED* left rear door release button
- need intercooler
- SS brakeline question.. crush washer
- Finally an SS panel!
- New Owner 2008 SS
- All Black Air Intake
- Rear seats in a Panel SS.... Worth it?
- P0101 And Pending P0101, P0191
- HHR SS Trans PN#
- Clicking noise when i turn to the right
- Southern Ontario??
- Curiosity
- What you guys think of my color option?
- LNF Engine Tick
- Sagging front bumper, clips wont hold
- misfire cylinder 4
- MevOTech CMS50174
- Brembo rebuild question...
- I want to add an oil pressure gauge
- Decent replacement turbo setup?
- New to the site!! I have a 2009 HHR SS panel
- Another Brembo question
- I'm Truly Impressed
- Rear Caliper Emergency Brake Sticking
- What is the red connector on the steering wheel control?
- planning on getting the SS dynoed (again) soon but need some input on prep
- HHR value
- P0455
- 155MPH ECO Utility Sleeper – 2008 Chevy HHR Review
- Whoa....I'm back?!
- Just got a blue ss with 148k
- HHR SS 2008 shuts off while driving and indicator flashes Low Fuel! But there is a t
- Stuck Brembo Pins
- Marking Catalytic Converter
- 2008 HHR SS running hot
- Codes P0455, P0457, P0011, P0451 and rough start
- Part Number for Sunvisor Retainer Clip on SS
- Horsepower Question
- Vehicle Ramp angle for a Stock Height SS
- Rear Flush Sub box?
- Beautiful 2010 SS w/23k Miles on BaT
- Any 1/4 mile racers have any advice.
- Odd question
- Worth it to buy an SS?
- Any Mod ideas for a 2008 SS?
- Side Skirt supports
- New member.
- Black 2008 SS questions.
- No crank
- 5 speed manual can't shift to 5th
- Tire Pressure Monitor System Doesn't Update After Tire Rotation
- 2009 HHRSS Needs a new engine
- Thank you!: Key fob: "Real Men Of Genius"
- Premium fuel
- OEM "Grey" shifter boot w/black threads.
- 2009 SS 5 Speed Driver side Axle shaft
- Speedometer
- Many Thanks to ZZP
- Limited slip G85 Oil change/additive
- Racing HHR's and Cobalts
- $15k for manual with 50k miles or $8k for auto with 170k?
- 2008 HHR SS engine replasment how too
- New Flywheel Aluminum vs Steel
- ZZP stainless cat back exhaust
- Flat towing an SS behind an RV
- Damage to intercooler after hitting a deer??
- HHr SS Electrical Problems Growing
- Radiator fan
- Fe5 struts
- Intro to Lil’ Deuce
- Rough running after throttle body cleaning
- 162K Mile 2008 HHR SS Maintenance History
- Metal grinding noise while driving
- Anyone want to sell me their SS?
- Taking Apart Injectors
- Anybody know the owner of this panel SS?
- HHR SS grille part number
- Shift light
- P0101
- Common issues?
- Another New SS Panel Owner
- SS Springs Help
- LHU Swap question
- Got my HHR SS yesterday for 5K
- Timing Chain Slack & Cold Startup Rattle
- Steering shaft
- Turbo going bad?
- Back for the second time
- '09 HHR SS auto Need CV axle confirmation
- HHR SS Launch Control Settings
- Odd sound update and some more questions
- cost of 2009 SS model
- Odd sound
- Dumb Comment & Question About Gas Type
- coolant & oil mixing
- Bent crankshaft
- Clutch Spring
- Probably the dumbest idea ever but.....
- correct size map sensor
- Factory 18” SS wheel finish
- Door Lock Issue
- 2.0 to 2.4?
- Timing chain replacement
- HHR SS intermediate steering shaft
- trying to get a little lower
- Order SS Shift Cables?
- Turning issue '09 SS Turbo
- Anyone know where I can get a 09 LNF short block or running engine?
- Wish I had kept the SS.
- Tie rod ends for SS
- Brembo Speed Bleeders
- Light clicking noise when in boost
- Could this be the Holy Grail SS AA5
- RPO Code
- swapping complete rear suspension
- Fuel Pressure Issue
- AutoX HHR SS advice
- 08 vs. 09-10 engines
- I just bought a rough 2009 HHR SS
- Turbo Heat Shield
- Charge pipe question & others
- 08 HHR SS Aftermarket Manual Shift Knob
- Just picked up a beater HHR SS. Waterpump tips?
- headlight mod.
- Key fob programming
- Just picked up an 08 SS, 9 years late to the darkside!
- P0101 issue
- Noob
- ZZ Performance or other tuner?
- Rear parking brake cable removal
- Dynoed the hhr ss auto but had issues
- 2.1 LEF built motor build
- Was the SS built on its own assembly line?
- exhaust Question
- Seat arm rest compatible
- bow tie emblem
- Manual trans question
- Latest mods
- Bought another 09 SS
- SS Lower Control Arms
- Leveling Springs
- Too Many Error Codes
- Front Sway Bar Removal
- Any info on atk motors?
- Bleeding Master Cylinder & ABS
- Another Dealer Horror Story, Part I
- 2.0 question
- Getting a Stock of Parts?
- Intercooler
- Normal turbo noise under acceleration
- Doug score....
- Customization
- What is this thing?
- error code P2188 / new owner tips wanted
- Seat plug ID
- Under hood insulation?
- Manual Transmission Parts Availability
- Ldk swap
- Competition Mode/Launch Control
- Balance Shaft Chain Sprockets
- FINALLY grabbed a set of SS rims!!
- Downpipe, is this stock or aftermarket?
- Possible Issue from Tune
- K&N Intake - 63 vs 57 series
- Dash kits - LT vs SS Interior Trim pieces
- No coolant temp or fuel pressure
- I've gone to the darkside
- P0101
- engine surges at idle 2008 HHR SS 5 speed manual
- Oem boost gauge question
- Engine power loss during hard pull
- fog light question
- timing chain question
- New HHR SS Member from NC
- New to the hrr ss
- How much is a 2009 Panel SS Worth
- leveling out stance
- Inner crankshaft sprocket gm 55557168 or gm 12462713
- boost turbo issue
- The HotWagon has a new sister!
- Too much boost ??
- Front Driver Rotor Smells Hot
- Dumb question about coolant and the turbo
- grill emblem
- It's...GONE!!!
- Boosting issues
- Ongoing saga advice or tips when replacing head
- SS Wheel Size
- clutch advice needed !
- Clutch woes ?
- wheel hub-to-knuckle spacer
- Is RPD customization possible?
- A-Pillar trim with and w/o airbags difference??
- Hhr temperature question
- My Red Panel SS on Ebay!
- Under boost!!!! WTF!!!!
- knock sensor help please
- Caliper question
- Cooling Fan Running After Turning Car Off?
- Check Engine Light 2010 HHR SS
- Check List for HHR SS
- Center cap
- New member, just got a panel SS
- Wheel well insulation
- Charge system light
- New to this forum, Question
- Lower Control Arms
- Front rotor and brake question
- LDK Build 2.0
- Boost gauge still available from Gm
- Backup stock tune?
- HHRs in the One Lap Of America race
- Front splitter
- Finally got it 09 quarter panel ss!!
- Boneyard SS in Tulsa
- SS front struts/springs
- SS Turbo pistons
- FQ7 4.05 final drive transaxle
- Advice from you current owners I'm looking at a specific vehicle and have some questi
- Service Air Bag
- Does anyone have production figures for the SS by exterior color
- What's your highway gas mileage ?
- Decode VIN Help
- Dashcontrol obdii display in dic
- SS interior question
- 09 Front end noise over bumps
- Pennzoil Euro L hard to find
- Whats the differance between SS and LT radiators?
- Hhr ss catback differences
- New Wizard Cooling radiator install
- HHR-SS show
