View Full Version : 2.0L Performance Tech
- in need of a co-pilot, lol...
- Normal driving conditions
- Scan crazy
- Home Made COLD AIR INTAKE
- In need of a TUNE...
- 956
- Tune info needed
- Low boost
- Any 2.0T techs out there in the Vancouver Cda area?
- New 'gasoline' 'tune' for you to try.
- Code P2090
- Aluminum Radiator
- Mod help
- Codes are showing P2187 and P0304
- Several tunes, boost degrades over time?
- SS Clutch question with tune
- 2bar & 3bar E24 & E$& 'tunes' attached
- Boost Wanders
- Nitrous LNF
- whp vs. engine hp
- Help with P0017 P0016.
- Hptune wanted
- Old rookie I got to start somewhere!
- LHU Swap question
- performance ignition
- LNF RPM shift points
- Ok silly question but.2.4 with 2.0 head turbo?
- Engine performance handbook
- PCV fix, fuelling fix
- high presure fuel pump
- Trifecta GAS tune?
- ZZ performance EU GM 3rd Gen 2.0 motors
- bog and boost problem
- HP Tuners Vs GM performance
- Which Gas Grade is Better
- If you can, you have got to try it...
- Trifecta ECM question?
- Something in the way SShe moves
- Map kits. Is this the same thing?
- Performance comparison 2.4L with Tune v/s Stock SS
- Seafoam ok ?
- Ticking engine noise (actually a wheel bearing hub)
- swap in 2.0lsj in place of dead 2.2 l61
- Repairing a mu3 / f35 transmission
- Down pipe with only one cat
- Downpipe gaskets
- Turbo upgrade
- Low Boost
- ecm pinout 2009 SS with automatic
- Air Flow at 23 LBS Boost
- Oil catch can - reader's digest version
- Chinese Turbos
- Vcm suite owners, i need a stock file for an automatic
- obd code
- Hp tuner vcm suite not seeing o2 readout
- Installing a Cold Air Intake
- Trifecta tune
- zzp catted dn pipe??
- 2.0 LNF GoKart
- HHR SS thermostat
- Ttr engine mount installed- got pics
- Newb here....Tuning questions
- Can you read spark plugs? What's up with this one?
- What is the easiest way to replace lower intercooler pipe?
- I've lost boost after BOV replaced!
- SS fuel injectors question: upgrade?
- EPS 60Amp fuse keeps blowing
- Problem With HP E47 tune
- 2008 ss ecm pinout
- Trifecta Tune Error
- Water/Methanol Injection
- New to HHR
- Changing tunes for ECM
- Big turbo wont boost past 7psi
- 2.0 LDK Build
- DIY IC pipe
- 2.0 Crate Motor ready to go in
- Dual gauge pods in dash surround
- 2.0 crate motor from zz
- Bringing back that 'old-school' wonderful, vacuum advance, part-throttle feeling...
- Any performance gain IC pipe
- DEI heat soak socks could cure your fuel issues
- Look what jumped in my truck and followed me home
- Are We being Tricked by Vendors & Cold Air Packages
- Engine Failure
- Stock Boost around 10psi
- Misfire and turbo issues: yet another thread
- Installing an Oil Catch Can
- Oil catch can idea's
- Spark Plugs - Good to have, better to understand
- Trifecta trouble
- Detonation problem I think i found the fix
- K&N air intake
- trifecta cable question
- Any body used this yet?
- Intake
- Question regarding replacing downpipe
- TTR Manifold Question
- SS HP tuners auto and pump gas tune
- Genuine Saab.com IC pipe
- new motor and turbo
- I think I found out why this HHR SS was traded in, I think?
- It's amazing, that a piece of plastic tubing, can make such a big difference...
- hahns poo87
- just picked up a 09 hhr ss mt... few ?'s
- old or new?
- hhr ss
- Hot side IC pipe
- I made a mistake,
- 22psi stock tune.
- Camshaft Postion solenoid
- charged piping wrap
- HP Tuning Dyno results.
- Dyno Results: Trifecta E-47 base tune (pics and video inside!)
- Trifecta question
- LNF STARTER FLASH a basic starter "tune"
- Dejon Powerhouse "air intake"
- Ss cylinder head replace
- What Downpipe to order?
- Low Boost
- Any thoughts or comments on the Hahn Tune?
- Resonator vs. Muffler
- Tuned Auto Folks I Need Your Help...
- Trifecta
- HP tuned...
- ZZP performance tune???
- best option for a tuner?
- Love HHR's and looking at a frickin gem
- Lower Map BLEW OUT of tube!
- Electric Y-Pipe?
- Any SS tuners in Oklahoma?
- K & N Filter
- BOV guys..I need your help
- ZZP header/downpipe combo
- Please Tell Me GM Upgrade will make me smile lol
- Forge vented BPV guys.
- Big turbo HHR SS 2nd gear pull 93 octane
- 2009 HHR SS 5spd
- Flash Cable
- ZZP 200 Cell Catted downpipe?
- anyone know a good hp tuner in ohio?
- Finally consistant boost
- LNF specs , & part numbers
- Need a tuner, Trifecta is not helping me....
- HHR ZFR dynoed on 91 oct
- best obd reader
- Why is the red line so low?
- Need Help..Not sure what CAI to purchase
- TMAPS and MAF and ECU
- New tune problem!!!
- intercooler/piping kit benefits?
- superchips with stage 1, anyone got this combo
- HHR SS no boost misfire hesitation no power
- Got my tune done today...sweet :-)
- HHR SS Shutting off / Running rough for about the first few minutes each morning ?'s
- Are Cobalt SS and HHR SS Intercoolers the Same?
- torn, upgrade and tune or not
- Trifecta budget vs Full version
- Turbo
- Best BOV?
- What mod did you do first??
- My 25g arrives today!!!!!!!!
- LNF Tuner
- HHR SS won't start after Trifecta tune - HELP!
- what are my chances of getting a code with a k&n filter
- GM upgrade kit
- p0236 code
- Anyone running 15w40?
- Forge VENTED bypass valve vta
- PCV in line catch can anyone install one what results did you have
- Trifecta
- Aftermarket intake help
- K&N lid important??
- E85 tune
- New dyno
- Engine build pistons
- 3bar sensor
- bigger wheel for borg warner k04?
- Open downpipe opinions
- 5th injector
- GMPP Stage 1 - Turbo more audible?
- Help me understand Bolt ons please.
- Hhr ss turbo info?
- More power. better turbo?
- Fuel pump help
- Redline worry/question
- The Dirty Subject
- Tune question about hp numbers, fact or fiction?
- CGS Axle-back exhaust
- Intercooler Piping upgrade!
- Tuners in PA or MD?
- HP tuners datalog questions?
- The reason I bought I/C piping
- Intake headlight for relocated mafs??
- Got the tune today
- What am I missing?
- Fact or Fiction - No BOV = Bad?
- Finally getting my turbo upgrade installed on Jan 4th
- Did ya get a Downpipe for a SS Auto for Christmas?
- Best mods for engine perforemaance HHR SS
- Ss exhaust
- Turbo boost question
- Has anyone swapped an SS engine/tranny into a non-SS HHR?
- Hahn Race Exhaust
- 801racing Power Pulse adds Horsepower?
- Stock muffler offset/length etc?
- Intercooler piping
- Pulled the trigger on the Stage kit turbo upgrade
- GMP Upgrade Problems
- Is this Trifecta "canned" tune worth $200?
- Tune vs Factory question..
- Tune with or without GMTU sensors?
- Cobalt Cold Air Intake on the HHR SS
- my 0-60 mph time manual HHR SS with tune
- Question on Liftless Shifting
- SS air filter box top off
- 0 to 60 time on a SS automatic with a GMTU?
- Great customer service -forge motorsports
- Dejon cover and best intake ???
- ZZP Cams
- Zzp ZFR bolt-on turbo upgrade
- Custom Short ram!
- MAF relocate/BOV?
- Mustang Dyno Failure
- Question about Exhaust
- Coilover question verus struts
- What Spark Plugs Should I Use?
- For all those guys looking for a Trifecta tune
- Trifecta premium tune
- Nitrous??
- 22 psi - yellow or green spring
- ZZP LNF Intake
- Oh do i have a fun weekend ahead.
- Air filter
- Dejon Charge Pipe Interferance
- Torque specs for zzp stage 4 clutch??
- Dealerships reluctant to install GMTU!!!
- Tune after downpipe?
- Zzp engine
- Got my Trifecta tune yesterday
- Built engine?
- ZZP intake installed :)
- Superchips?
- Gmtu
- Getting my intake and tb ported and polished.
- Tuners
- Bov
- Question about Trifecta ..
- 2010 saab 9-3 turbo lnf motor...
- Any reputable tuners in San Diego?
