- replacing frt struts, which ones?
- Uneven Brake Pad Wear
- Lower control arm rear bushing
- Brake hose banjo bolt size
- Good source & brand for F. suspension parts.
- Front Sway Bar Replacement - Degree of Difficulty?
- Brake Fluid Question
- Front end noise
- Brakes not always responding
- Need help identifying master cyclinder
- 2009 Ls needs sway bar link length help
- Lower control arm bushing - conventional wisdom
- Wheel shift
- Looking for SS Outer Tie Rod Ends
- HHR SS Rear brakes
- Pulls right letting off brake.
- noise/shimmy when applying brakes
- Any difference in struts with a 2LT rental HHR?
- Any issues with KYB struts
- Rear toe out
- Torque specs on ball joint bolts
- FE3 strut warning
- Upcoming front end work- alignment?
- Noisy brake rotors
- SS rear caliper adjustment for the emergency/parking brakes
- One Year Later, Replacing LCA’s Again
- Brake pedal goes to the floor
- Abs module replacement
- ABS/traction warning lights
- Disc brakes
- Rear LCA bolt stuck
- Need steering knuckle
- 2008 Cobalt brake pedal sinks when going forward, but not in reverse
- 2011 LT undercarriage rattling
- P0561 traction control
- P0573
- Replacing sway bar
- Ball Joint Replacement: to lube or not to lube
- 2010 LT 2.2 Suspension+ Replacement: Strut/Shock/Link/Speed Sensor Hub/Rotor
- Brake issues
- new disc brakes too tight to turn
- Rear coil spring insulator
- Rotor opinions?
- Who makes the best upper Strut bracket???
- Tall Rally style Coilovers
- Has anyone used Hi Jackers air shocks in the back?
- Pad clips too long??
- Strut noise, Jounce bumper
- Cheap/not so cheap front rotors
- What is needed for a rear disc axle swap?
- rear disc conversion
- Looking for air bag suspension parts
- 2006 abs light on
- Tourqe specification
- pads and rotors for 2009 lt?
- Shocks and Struts are on.
- odd brake noise when stopping
- SS brakes on an LT
- Issues with ABS traction Control and cruise control.
- 2 Inch Drop Causes Shudder
- C0201 code fix
- What Do I Need Next?
- Going back to Stock-ish suspension
- Raybestos Front Rotors
- ABS Brake and Traction control lights
- ABS braking weirdness on 2010 LT
- Got some clunks
- Stabilizer Sway Bar Links -- What Length?
- Braking and ABS help
- Loss of pedal resistance
- Line lock, roll control
- ABS control valve / module
- Rear spring question
- Strut Bolt
- I wish to lift suspension of HHR.
- Upgraded my suspension - SS rear axle, other parts
- Spring rate rear suspension
- Poor turning circle
- -3 degrees camber after LCA change
- Toss Them or Resurface Them
- ABS problems without code or light
- No banjo washer on front calipers!? No leaking 07 HHR Help!
- Front brake lines
- how adjust parking brake(Emergency brake)?
- Rear lower shock bolt stripped/cross threaded
- Rear shocks suggestions @ lowering with springs
- air suspension
- 2in Hitch Adapter
- Car wanders after new tires installed
- KW coilovers
- C0550
- Front end bushings
- Front End
- SS Eibachs
- rear bolt lower control arm stripped 2008 LT Panel
- ABS repair
- Need suspension suggestions
- Fuel Filler tank hose, or?
- Rattling noise under dash when I apply brakes
- Service Traction/Service ESC Message
- Spongy brakes
- Mechanic Can't Replace Front Lower Control Arm
- Another ESC problem
- Control Arms 250mm vs 300mm FE1 vs FE3
- Moog problem solver control arm
- Rear drum brakes, how many miles did you get?
- Drum brake conversion
- sway bar end link question
- Replacing standard SS brakes with Brembos
- Diagnosing Stabilizer Links and Bushings
- 2010 HHR Bad braking system on bumpy roads
- Half shaft stuck in hub?!
- Ball Joints and LCA
- Sinking brake pedal 06 HHR
- rear calipers dragging, fixed
- Cleaned up the Brembos
- Bagged hhr's
- lower control arms
- SS struts on a 2lt?
- Lower control arm body mount bolt and cage nut
- Rear brake drum diameter
- Brembo Upgrade Questions
- Need a rear brake bleed screw
- Control arm bushing test
- SS HHR parts inter change with other HHR models
- Power Custom
- Steering help please
- Steering knuckle replacement.
- Rear brake diagram
- Adjustable camber bolts
- FE1 vs FE3
- thumps
- 2010 LS Suspension Parts Help
- Lowering rear
- Front parking brake cable
- Brake Light
- ESC Active message after rack replacement
- Continuous front end vibration
- Time for struts and shocks..
- Front suspension clunks and creaks that seem to be temperature sensitive
- Squeak squeak. What? Hellpppppp
- LT or SS steering Rack
- Brakes
- Sway bar bushing bracket bolts????
- "Sport Tuned Suspension" Help?
- Shock/Strut ?
- 2011 LT rear end sway and bounce
- Rear Backer Plates - need new or close to new
- Front & Rear Suspension Refresh - Parts List?
- sumthing still loose?
- Bilsteins
- Rear shocks & Coil springs Replacement
- Front Control Arms
- SS front end problems
- SS lower control arm rebuild
- Lower control arm bushings or entire arm?
- 'Performance' lower control arm?
- Brembo swap and F23 swap on auto SS
- front end shake
- lca replacement
- LS Front Warped Rotors
- Wheel Cylinder
- Something on front end broken
- Noise solved by new shocks
- Control arm rear bolt was seized in bushing
- New MOOG Control Arm Bushing?
- Rear sway bar questions
- Quickstrut
- Urethane Control Arm bushings- the easy way
- SS (FE5) replacement
- Upgraded Suspension Parts
- 06 HHR Ball Joint Bolts
- New components... 4 years ago; looking for advice
- My front end clunking, is there an echo in here?
- 07 hhr coilover suggestions?
- Freshened things up a little
- Air Shocks or Coil Overs for rear?
- Swaybar end links
- Abs, brake and traction light
- Canuk Motorsort Springs question
- Control Arm Bolt Sheared
- Rear Shock Install confusion ......
- Anybody noticed the bolt size change on the TTR Rear Sway Bar
- 08 HHR SS Front Stabilizer bar.
- Suspension Popping/Clunking
- new here rear axle issues
- 2009 LS springs/colbalt
- 2010 hhr ABS wiring ?
- front end noise...killin me!!!
- Any sway bar bushings better than others?
- SS Caliper rebuild and paint
- SPRING question.
- Dumb rear spring install question...
- Front end kits
- Suspension issue on 1LT
- Cobalt rear axle on an HHR
- Strange Vibration Between 50 - 65 mph
- Front Sway Bar Diameter
- strange brake problem
- Negative camber-new lca-toe out
- Steel LCA vs. Aluminum - Why not?
- Power Steering issues still after motor change
- Shield loose on struts
- Rear Axle Bent?
- Sway Bar Bushing 10mm bolt stuck
- What is This?
- Shocks
- Brake pedal height adjustment
- Replaced BC coilovers with KW variant 1's on my SS (pics)
- Suspension Newbie
- SS-front rotors and calipers to an LT2 model?
- First Post Here - 2008 HHR SS LCA
- ABS / TC lites on then off
- KW Coilovers Variant 1 Suspension help
- Moog LCA bushing K200792
- How are the Problem Solver LCA bushing holding up?
- 2008 hhr ss
- Love my HHR SS
- OEM struts vs. Quick struts
- Anti-lock brakes engage when coming to stop
- Hard right turn clunk
- Master cylinder: repair / rebuild kit
- clunk noise advise
- Pssst, Hey You! Yeah I mean You, lookin' for Part Numbers?
- you guys are correct again!!
- Undiagnosed noise
- 2008 HHR Brake N Shake
- Front End Knock that goes away in 15-20 min.
- Lower Control Arm - Vertical mount bushing replacement
- Sway Bar Bushing Confusion
- Independent Rear Suspension
- Brake pulsating
- Ss fe5 struts and springs
- Brake pad material
- Can ABS Wheel Hub Replace Non-ABS?
- Eibach pro kit
- KYB Struts/Eibach Springs Installed, Veritcal Play in Passenger Side Strut Shaft
- How to Replace the Master Brake Cylinder on 2006 HHR
- Front rotor dimensions
- clicking sound when brake pedal depressed after brake job?
- Need help with shorter struts.
- Advice
- Brake fix tsb 09-05-22-001a
- Intermediate Steering Column Shaft Issue.
- Need Advice buying new control arms.
- HHR Lift
- Do I already have a rear sway bar?
- Struts for my 2008 hhr
- Help- 2010 rear brake shoe replacement
- Brake shake fix
