- Local mechanic doesn't know what to do??
- P0243 - just swap the solenoid?
- lower ball joint
- How to determine if engine rebuild is worth it?
- Quick Question
- Auto Transmission Fluid Level Erratic
- Red oil light
- Can't find a front wheel hub spacer
- No crank
- Right front "hummm" at 45
- Swapped rack and pinion/MEVOTECH TXES80479 the best?
- $500 to Program ABS Module
- FE1 or FE5 steering rack?
- BCM problem? Source for parts?
- Caliper bolt needed
- Coolant leak though charge pipe connections
- Auto Transmission Issue
- Dirt in camshaft solenoid?
- Good mechanicis
- Current Brembo Brake Preferences
- SS Front Bumper Cover - anyone try aftermarket?
- Motor knocking
- HHR SS air box mounts
- Intermediate steering shaft
- 2009 Chevy HHR Stalling Issues- Please Help
- Leaking charge pipe
- Newbie here,
- fuel injector problems
- Swapping turbo today
- What parts along with new turbo?
- Misfiring
- Front Hub? Thump Only When Cold
- Steering Control module 25819157
- HHR SS Shift Cable Damage Info
- What does this mean? (Coolant fill cap)
- 08 SS f35 to f23 conversion
- Knock sensor swap
- Wheel loose, shaking when not turning
- Brembo questions
- Compression test, piston rings, head gasket
- Possible Ball Joint for SS?
- Help with compressing rear caliper
- RCDLR Replacement and programming
- How to replace SS thermostat
- Replaced 5-speed Shift Cables
- Coolant leak somewhere
- Having problems mounting rear calipers after replacing rotors and pads
- Dash Lights
- Where to order a replacement shift cable assembly?
- High rev at idle after map and maf change
- Engine cradle
- 2009 SS Cooling Fan Pigtail/Connector
- Engine Rattle During Acceleration
- Cleaning coked valves
- One disaster after another. Need help here
- AFR on RPD no data available
- After market Turbo for 2008 2.0 SS
- Front Lower Grille Paint Match
- HPFP End of Life Tell-Tale
- What are AC Delco or aftermarket part numbers for '08 SS non-brembo front brake pads
- Control arm
- mu3 transmission removal
- Boost Control Solenoid
- Shock replacement advice requested
- Outlet Duct, Valve piped to Cam Cover Repair HELP
- steering angle sensor/power steering
- Pop goes the chain guide
- HHR SS Intermediate steering shaft
- SS Clutch Take up too Low
- TPM and key fobs
- Cold Start Noise
- Catalyst and EVAP I/M
- Read this and thought it might help someone in the future.
- Turbo coolant line.
- Fuel System question
- SS Manual Fluid
- New to me SS - suggested maintenance items?
- 2008 HHR SS engine replasment how too
- SS Balljoint stub diameter
- Transmission problem
- Fuel Injector Pressure sensor location
- HHR SS rims
- 2008 Yaw Sensor
- Airbox bolts
- New HHR SS OWNER NEEDS HELP
- Water temp range
- Transmission mount part number
- Replace cam chain without removing cam phasers?
- Reprogrammable performance display
- Do I need a new hub bearing?
- Ball joints idea?
- Coilovers HHR SS
- Oil light comes on at idle.
- Braided line from Cam Cover to Turbo
- Knock sensors P0332
- Coolant has been warmer than I like
- Manual transmission 5 speed
- Slight Engine Shake
- Both Control Arms in Stock Now at Rock Auto
- Split my hot side pipe - Options?
- SS ball joint famine
- Side skirt question?
- Broken keyway in crankshaft
- What symptoms does the carbon build up cause?
- Front Control Arm Front Bushing Install
- 2008 Hhr ss air filter replacement
- Stalling Issue
- Rear Caliper Parking Brake Srpings?
- P1101 obd code
- Manual SS Axles
- Emission Problem
- Replacing 08 SS suspension 🥺
- Power steering
- SS Rear Shocks
- Cam Cover Quick-Disconnects
- ZZP Replacement Couplers install?
- SS 5-sp trans mounts
- Timing Chain Crank Sprocket
- Boost Gauge Availability?
- 2008 HHR SS manual trans clunk
- RPD Cam Advance display
- Stumbling at acceleration
- Front Strut Hat Orientation
- SS TPMS sensors
- FE5 ball joints, again
- K&n air intake and programming.
- Front Strut Mounts/Bearings
- Brake Fluid
- Splash protector got ripped off
- Time for timing chain replacement
- No start after engine wiring replacement.
- Rear Calipers
- What's my best option here (FE5 suspension related)
- 2.0 5 speed engine R&R
- Rear rotor size.
- Intermittent loud, vibrating & under-powered motor
- OEM Brembo Pads
- More Timing Chain Woes - 2009 SS Manual
- Stalling with no power to the ground. HELP!!!
- 2009 SS Clutch Slave Bleeding
- Need some advise for Code P2261
- SS front sway bar end links - any to avoid?
- 2008 HHR SS anti freeze in oil pan
- Code P2178
- Evap Vent Solenoid
- SS Manual Acceleration Thud when already in gear
- Clutch Sensor
- Removal of the 2.0 turbo's air filter housing
- Heater core removal
- SS Won't Idle
- Coolant pipe
- "Low Coolent Or Electrical Issue?"
- Strut Replacement Noise
- 2008 SS Timing Chain Time - GM or aftermarket?
- F35 MU3 shifter cables GM#15939191
- Does this head gasket look like it was leaking near no 1?
- turbo cool line part number
- Inlet on valve cover removal
- Struts
- Manual transmission woes
- Hhr ss shifter cable woes....
- Engine cutting out
- Difficulty identifying leaking turbo oil line part number
- Map sensor locations amongst other issues
- Auto trans issue, from overdrive to fourth gear
- P0299 issue solved
- RPD stopped working???
- Injector cleaner
- P0234 - again
- Lots of oil in cyl #3
- 24 psi boost, but no "boost"
- Possible fuel pump issue
- P0299 underboost
- Ongoing problem with car sputtering and dying in traffic or while sitting idle
- SS Maintenance Items
- Rear axle spring bumpers part number?
- P0299 and p2261 trouble codes
- Antifreeze Leak Under Thermostat Housing
- Turbo Impeller. Should I clean it?
- Apparatus Bolted to Intercooler
- Cleaning Oil Cooler
- Lowering Springs Totally Collapsed-HELP
- Blown engine?
- GM Turbo Upgrade (flash ECM) question?
- Carmax put in KYB Excel-G Struts in my SS?
- Security code needed for replacing ECM?
- Overboost and falls off
- Balance Shaft Sprocket Bolts
- Boost lag
- Turbo coolant banjo bolts torque specs
- Brake Bleeding Procedure
- reduced power, engine disabled
- Help with my problem list
- 299 codode underboost
- Tools needed to remove air cleaner assembly?
- Problem with AC Blowing warm part of the time
- Output speed sensor
- Sticking Clutch Pedal
- Rebuilt turbo problems
- Replaced Starter, HHR SS Still Won't Start
- P0016 / Boost / Overheat - Help A Girl Out!!
- How to split open a mu3 transmission ona HHR SS 2009
- Torque specs for oil & coolant lines
- Clip on air box
- 08 SS code issues
- Looks like I might need a new cooling fan assembly...
- Boost issues
- Replacing Timing Chain
- Boost gauge question??
- Something Weird Going On
- found oil on cold air side of turbo
- 2007 and 2008 hhr
- Outside temp sensitive cel
- 204,000= p0016
- RPM does not reduce when shifting
- Cold start noice
- Help me I'm melting! Front turn light lenses.
- Boost Problems
- Engine reduced
- P2261 code
- Timing Chain Jumped Tooth
- boost surges
- Severe oil use at times / no turbo boost at times
- Boost gauge going backwards.
- Front hub/bearing tolerances
- 2.0 Timing Chain Problem at 61,000 Miles?
- Turbo install
- Bad Turbo?
- Auto trans and tune
- knock sensor
- SS ball joints
- boost gauge stopped working
- HHR SS How many cats?
- Replaced the HPFP and now I have a no start condition.
- Bank 1 O2 sensor 2 fault
- Turbo only work when fuel lite is on
- SS Lower ball joint replacement
- Automatic ss axles
- CEL, P0010, thinking it's a fluke.
- Forge bpv
- Charge Air Pipe Leak = GMTU Low Boost?
- Transmission to engine...bolts how many
- P Codes popping up
- Moog Control Arm Bushing 6698
- P0089 and P0304 plus no start condition
- 09 SS Overheated - What now?
- Keyless reciever inop.
- Front Sway Bar Bushings?
- Rear O2 sensor not ready
- Hhr ss stage 1 turbo erratic
